Weight ?
  • lucey
    • Jul 2005
    • 95
    Weight ?
    Looking for a rough weight of my 2000 SAN with a DHL trailer with say half fuel. I am guessing around 3500-3800 lbs. Is this abouot right ?
  • TRBenj
    • 1681
    • NWCT
    RE: Weight ?
    I think your guess is on the light side. Check the reference section on CCFan to get the dry weight of your boat. Add ~1200 lbs for a tandem axle trailer and a few hundred more for fluids. Add some weight for gear as well.
    1990 Ski Nautique
    NWCT
    • MNSuperAir
      • Sep 2005
      • 591
      • St Paul
      • 2016 SAN 210
      RE: Weight ?
      Should be closer to 4500-5000#'s
      2016 SAN 210
      2006 SANTE sold
      2001 SAN - sold
      1991 Sport Nautique - sold
      • lucey
        • Jul 2005
        • 95
        Weight ?
        Okay so 2900+1200+400(gear+fluids)=4500 ish. On a tandem DHL what do you think the tongue weight would be ?
        • MNSuperAir
          • Sep 2005
          • 591
          • St Paul
          • 2016 SAN 210
          RE: Weight ?
          Tongue weight is probably less than 500 lbs but not much.
          2016 SAN 210
          2006 SANTE sold
          2001 SAN - sold
          • Rick
            • Mar 2004
            • 1250
            • San Diego, Ca
            RE: Weight ?
            The dual DHM weights 1100lbs. My 2000 196 weighs 4000lbs with all fluid and skis. The brochure says the weight difference between the 2 boats was 200lbs. I think 4500 is a good weight to use. Being a dual axel trrailer the tongue weight is between 250-300 lbs. I tow with the ball 19" off the ground loaded down.
            Nautiqueless in San Diego
