Raw water pump impeller replacement
  • uncle-buck
    • Jun 2004
    • 29
    • Houston, TX
    I want to replace the impeller in the Sherwood raw water pump in my 1990 Ski Natique - and am not sure the pump is installed correctly right now.
    Do I have a right hand or left hand motor? Sitting in the driver's seat and looking back at the front end of motor, everything turns clockwise when the motor is running. It's a left hand motor, correct?
    The instructions with the impeller talk about the cam screw facing the proper direction. What does that mean? Does facing towards the engine block mean the screw head and engine block are on the same side of the pump body?
    Thanks for any advice on this.
    \"Helping you make smart choices about your money - so you can live a better life.\"
