Caulk for Pitot Tube- What kind to use????
  • ffmedic74
    • 835
    • Lexington, KY
    I have to replace a cut pitot tube on my 05 216. What kind of caulk do I use for the thru hull area that the tubing goes through.
    Thanks!
  • wake_fun
    • 1330
    • CA
    • 1995 Super Sport
    3M Fast Cure 4200 or one of the others.........read about them here:
    http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
    I used 4200 on all my thru-hull fittings.
    Photo Album
    Ballast Install 1
    Ballast Install 2
    Amp Install
    PPass Install
    Alternator Install
    • DavidF
      • Sep 2004
      • 611
      • Austin, TX
      I use Boat Life Life Caulk. The 3M products are good, but hard to remove once cured.
        Another vote for Boat Life Life Caulk.
        • Rick
          • Mar 2004
          • 1250
          • San Diego, Ca
          If you haven't taken it off yet I would just knock the old pin holding the tube part to the mounting bracket and just replace the tube. no caulk needed.
          Nautiqueless in San Diego
          • ffmedic74
            • 835
            • Lexington, KY
            Thanks for all your input!
