WHAT TO CHECK or dealer......?
  • wake_fun
    • 1330
    • CA
    • 1995 Super Sport
    For this problem I highly recommend getting this:
    http://www.skidim.com/prodinfo.asp?number=DP6
    It is SO much better!!!!!
    :mrgreen:
    Originally posted by tski97
    On mnine, 97 sport, I can not get the fake a lake to pull enough water to keep the boat cool. I have found it is hard to get the fake a lake over the intake enough to make it work.
    Photo Album
    Ballast Install 1
    Ballast Install 2
    Amp Install
    PPass Install
    Alternator Install
    • linebacker55
      • Mar 2007
      • 44
      • Goose Creek, SC
      I had this problem on my 02 SAN. Wouldn't take a suction in the driveway, overheating, and such. Had already replaced impeller, and tore the entire cooling system apart looking for the problem. Put it all back together and filled the system back up and nothing. The problem, as i eventually figured out, is that you need to idle the engine at about 900-1000 RPM. Then the impeller wil develop enough suction to get the water up into the engine. Sounds kind of dumb, but the fake a lake isn't the most leak tight system, as already mentioned. Takes a lot to suck that water up into the engine compartment, so try revving the engine just a little in neutral with the water on and see.
      2002 Super Air Nautique
