Does it hurt to run your boat in gear while out of water?
  • smiley11
    • May 2007
    • 10
    Will it hurt anything to run it in gear while out of water?
    My boat has a switch keeping me from revving too much, while its in neutral.
    \'82 Ski Supreme
  • darrel409
    • Jul 2004
    • 566
    • San Dimas, So. Cal
    RE: Does it hurt to run your boat in gear while out of water
    It will burn up the strut bushing pronto w/o water to cool and lubricate. Oh, and that spinning prop is pretty dangerous too.
    • wake_fun
      • 1330
      • CA
      • 1995 Super Sport
      YES!
      Why do you want to run it in gear out of the water?
      You can rev it up without it being in gear.........push in/pull out the button by the throttle?
      Photo Album
      Ballast Install 1
      Ballast Install 2
      Amp Install
      PPass Install
      Alternator Install
      • richard
        • Feb 2005
        • 406
        • HK
        Sometimes we want to visual check the prop/shasft turning or a stuk trans will turn the shaft when in neutral on trailer,except connect hose to for cooling, shower the shaft strut so water can wet the strut while in idling speed it don't hurt any thing to your boat.
        • Andrew
          • Aug 2005
          • 891
          • Tuscaloosa, AL
          like richard said, as long as u keep the strut and the stuffing box wet it shouldn' harm the boat... ALTHOUGH i can't say anything for people who get a little too close to the prop.....
          • smiley11
            • May 2007
            • 10
            Thanks guys. I figurered it would harm a bearing or bushing.
            When I take my boat on the water it will slowly accelerate to about 10 mph and then stall or backfire. When I am working on the boat at home, in neutral, the gear-engage knob wont allow me to go anywhere near full throttle. I guess I could unhook the throttle at the motor and do it right?
            \'82 Ski Supreme
            • Andrew
              • Aug 2005
              • 891
              • Tuscaloosa, AL
              yeah, just pop it off and u can rev it as high as u'd like
              • C-Money
                • May 2007
                • 74
                • Kansas City
                Use caution when reving the engine with no load (i.e. no resistance on the prop)!!!!
                You don't want to over do it!!!
                • boatech
                  • Aug 2006
                  • 247
                  i check propshafts and props using this method. i use motor cycle chain lube in the strut bushing works great no need to really wing it up though just putting into gear is enough to check shaft/prop without lube you WILL DESTROY the bushing!! and yes stay clear of the prop it can kill you.
                  • Quinner
                    • 2246
                    • Correct Crafts
                    When revving in neutral push the throttle toward reverse that way the knob will not interfere with the throttle arm.
