Floor removal on an '03 Ski limited
  • 78LS2
    • Oct 2006
    • 183
    If i wanted to pull the floor up to gain access to the muffler area, how would I go about doing this?
    Also, can this be done such that the gas tank remains in place and the boat can still be run?
    I think that I have a leak somewhere in there, and want to take a look.
    Thanks!
    \'03 196 LTD
  • Eggie
    • Jan 2004
    • 110
    • PA
    RE: Floor removal on an
    Did you buy the boat new? If so, wouldn't the warranty cover that?
    2003 Ski Nautique 206 Limited, FCT, Excaliber 330, Midnight Blue - Silver Cloud
    • TRBenj
      • 1681
      • NWCT
      You dont need to remove the gas tank. The rear seat base and motorbox need to come out, and then the floor panel can be removed.
      Have you looked at the shaft packing through the inspection plate to see if thats where your water is coming from? Both my dad's '03 and friend's '02 are due for packing replacement.
      1990 Ski Nautique
      NWCT
      • 78LS2
        • Oct 2006
        • 183
        shaft packing is OK. last time I ran the boat water was coming up from underneath the rear seat, port side corner.
        The boat was bought new by my brother, and then on to me / my parents. The dealer might be able to squeak it through under warranty...but who knows?
        \'03 196 LTD
