Loss of acceleration 06 Model sv211
  • Mark56
    • Jul 2007
    • 36
    • AU
    Just wondering if anyone could help with our problem,after using our boat for 10 minutes we lose total acceleration if we turn the boat off.
    if you leave it running not a problem but soon as the motor turns off then back on we lose it.Once the boat has been totally turned off for 30 minutes to an hour it works fine then turn it off again same problem. Any help would be great as waiting for our dealer to get the
    diacom software.
  • Laptom
    • Oct 2003
    • 876
    • Eindhoven, Netherlands
    RE: Loss of acceleration 06 Model sv211
    Sounds like a fuel problem.
    • gnautiqueman
      • May 2006
      • 47
      It could be the computer, mine did the same thing (2006 TE 211), dealer said service bulletin had been issued and replaced under warranty, said if it was going to fail it would fail within first 100 hours. Mine failed at 25.
      • Roy
        • Jun 2005
        • 28
        Hi,
        I would contact your Dealer, he can fix it.
        Thanks,
        Roy
        • Quinner
          • 2246
          • Correct Crafts
          If you have perfect pass, we have had some issues with our 05' when using PP of the throttle cable not recoiling completely, when this occurs the throttle can be put hammer down and the boat may only do 20mph, or basically you are only capable of revving up to 2000rpm's or so. Usually shutting off and on both PP and the boat will solve problem if not you can turn the knob on the PP module to recoil it tight.
          Not sure if your boat is throttle by wire which could be a completely different set-up.
          • Benjamin74200
            • Jun 2026
            • 1
            • ANTHY SUR LEMAN
            • SV211 air nautique correct craft 2006
            Bonjour
            j’ai un peu le même problème sur mon SV211 de 2006 .
            Parfois la commande de gaz ne répond plus pour accélérer
            je peux enclencher la marche avant et la marche arrière mais pas moyen d’accélérer
            je suis obliger d’éteindre et de rallumer le moteur parfois plusieurs fois
            pourtant il garde bien le ralenti .
            peut être le TPS ?
            si quelqu’un a eu le même souci ?
            • JayG80
              • Dec 2006
              • 249
              • Santa Fe, TX
              • 2007 Ski Nautique 2002 Ski Nautique 1999 Moomba Outback
              Originally posted by Benjamin74200 View Post
              Bonjour
              peut être le TPS ?
              Hello
              I have a bit of the same problem on my 2006 SV211.
              Sometimes the gas control no longer responds to accelerate
              I can engage forward and reverse gear but no way to accelerate
              I am forced to turn off and turn on the engine sometimes several times
              Yet he keeps the slow motion well.
              Maybe the TPS?
              If someone had the same problem?
