I am lucky enough to have an awesome girlfriend, who bought me Wetsounds Pro 80's for my birthday. Now, I need to figure out how to run the wires. Does anyone have any suggestions? Should I go out and buy electrician's fish tape?
RE: Tower Speaker Wiring
Used 12ga solid wire as a fish line and a needle nose to catch it at the other end opening, ran one fish from R to L speaker hole then another from L down left side to exit hole at top portion of tower and a third from tower leg up to lower leg exit hole. Drilled 1/2" holes to start then a tapered bit to clean up the hole. Used 12ga speaker wire, finished hole with grommets and wires with braided loom both from cableorganizer, speakers used the Nuetric connectors. I think more time was spent figuring out where and what to get for the installation then the installation itself. May be a better way to do it however this worked for me.
Good luck with your install!!
Re: RE: Tower Speaker Wiring
Did you put anything on the end of the string to give it more area?Originally posted by bmh2208I think the easiest way to pull wires is the string and vacuum method. I was able to get the pull strings ran for 5 separate runs in about 20 minutes.Previous:
2011 Super Air Nautique 210
1994 Sport Nautique
RE: Re: RE: Tower Speaker Wiring
cut about a 4 inch square out of a grocery store type plastic bag - thin plastic - zip lock bags are a little too thick - tie the string around the bag as if you are making a small candy pouch stick the bag in the hole and vacuum the other end of tower - should suck right through2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
I was able to make it work by just tying a knot at the end of the string. You could probably fold up a piece of tape. The key is something that is pretty light. I just used a knot. Once I got to the third pull on one of the sides, a piece of tape or something would get tangled in the already pulled strings.
