Excalibur oil filter
  • Flyerace
    • 39
    Does anyone have a cross reference number for the PCM oil filter in the Excalibur? The PCM # is R077001. I'm looking for an off the shelf filter and the PCM # isn't cross referenced in the other brand's books. Thanks in advance.
  • Hollywood
    • Sep 2003
    • 1930
    • WIIL
    Take it to the auto store, and match up the threads and o-ring sizes. Then find the longest one in the same size. Might get you an extra half quart even.
    • ag4ever
      • 1180
      If it is the remote filter above the exhaust manifaold, then it is a "Ford" filter type.
      The motorcraft part number is FL-1A, and you can get it at wallyworld.
      • skinautique
        • 1749
        • Colorado
        Fram PH-8 if you want to use that brand. This will work on all excalibur engines.
        • tryan
          • Nov 2003
          • 267
          • gatlinburg tn
          i had a link for an oil filter test on ccfan or here. do a search or i'll see if i can find it. i would go pcm or motorcraft. IMHO fram filters are junk.
          red right return
          • surfsup
            • 84
            So does PCM use "Ford" filters on their Chevy block engines (i.e. Excalibur)?
            • MARK-S
              • 764
              • SE MINN
              • 1978 Ski Tique 1996 196 2001, 2002, 2003, 2004,2005,2006,2007,2008 196s Best boats made
              All PCM engins use the motorcraft FL-1A..ford block or chevy.
              I would use the FL1A from motorcraft. That is the stock filter on PCM from dealer.
              Life long Nautique guy
              Will ski anytime.
              \"SON WATERSPORTS ROCKS\"
              • ag4ever
                • 1180
                It is not that they use a ford filter on a chevy block, but more that they use one type of remote oil filter mounting bracket, and that unit uses a ford filter.
                The parts that attach to the blocks are differen patterns, but those should not ever be removed unless there is a problem with it.
                • SuperAirDave
                  • Dec 2003
                  • 78
                  • San Diego Ca.
                  • 2004 SANTE 210
                  I agree with TRYAN and MARK S..... I had an off road race car with extremely high oil pressure and would literally grenade fram oil filters. Talk about a mess!!! You could actually see the Fram bulge as you throttled the gas. The engine builder reccomended the Motorcraft FL1A due to its construction. Never had a problem again. Stick with the Motorcraft product.
                  Nautique... The final step up.
