Squeal as Prop Coasts to a Stop
  • dkerstetter
    • Jun 2006
    • 8
    • Windsor, CA
    I have a 2001 SAN. As the prop slows to a complete stop I hear a squeal which seems to be getting worse over time. I had originally thought the noise was coming from the stuffing box nut rubbing on the drive shaft, so this season I replaced the conventional stuffing box with an OJ Dripless seal; however, the noise is still there. Through process of elimination, I am thinking the only other thing that could be causing this noise is the strut bushings. Any thoughts or suggestions?
  • Andrew
    • Aug 2005
    • 891
    • Tuscaloosa, AL
    RE: Squeal as Prop Coasts to a Stop
    i would assume that it is the bushing as well
    • Mark56
      • Jul 2007
      • 36
      • AU
      Maybe the grub screws that are in the drive shaft flange that screw into the drive shaft have loosened and are hitting the transmission.
