I posted previously about how my engine takes 3 consistent cranks to get it started. I was thinking it was a sensor, but when it's started it runs great. Also, when it's warm it starts right away (when the starter turns). Now I'm leaning towards the starter. Over the past couple of weeks, the boat has not started on the water about once each time out. After we switch wakeboarders, I go to start it and nothing. The battery is a year old and seems strong. Also, I lift the engine cover and hear the starter relay clicking, but the starter doesn't turn at all. If we wait a minute and crank the key again it will start right up. I'm thinking either the starter has a loose wire (possibly corroded) or is slowly going bad. The boat is 1994 and I'm fairly sure that it's the original starter. I know electrical equipment goes bad on boats, could the starter be near the end of its life? Should I replace it now?
RE: Failing Starter?
I'd start with the starter relay, even though it is clicking. It is much less expensive to replace a $25 part than a starter, and if that's not it, you're only out $25 (and should probably replace the relay anyway).I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Re: RE: Failing Starter?
Originally posted by NautiqueJeffI'd start with the starter relay, even though it is clicking. It is much less expensive to replace a $25 part than a starter, and if that's not it, you're only out $25 (and should probably replace the relay anyway).Previous:
2011 Super Air Nautique 210
1994 Sport Nautique
RE: Re: RE: Failing Starter?
Absolutely. The one on my '94 went out in 2002 or so.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Also, check your battery connections. Both the clamp to the battery AND the connection from the cable to the clamp. A corroded connection from my clamp to the cable itself caused a row-in to the ramp once this year. Low voltage causes these exact symptoms as well.
Re: RE: Re: RE: Failing Starter?
Originally posted by M3FanAlso, check your battery connections. Both the clamp to the battery AND the connection from the cable to the clamp. A corroded connection from my clamp to the cable itself caused a row-in to the ramp once this year. Low voltage causes these exact symptoms as well.Previous:
1994 Sport Nautique
