Trailer problem
  • pipester101
    • Jul 2007
    • 34
    • Orlando, FL
    Trailer problem
    I have a Ram LIn Tandem Trailer for my 05 SANTE. I went to load the boat yesterday so i could clean it and i guess i had put the boat a little too much on the left side and the boat pushed the fender over just enought to rub the tires. I did not notice this at the ramp but later when i got down the road and the tire was smoking. I had to put the boat back in the water so i could try and fix it but i have tried everything, (crowbar, jacks,etc) to bend it back and it just bounces right back over the tire.
    Any suggestions.
  • jmo
    • Mar 2006
    • 707
    • MA
    RE: Trailer problem
    when you say the boat was too far to the left, was the bottom of the boat actually resting on top of the fender, or was it just right up next to it?
    I've been in the latter situation a few times due to loading on uneven (un paved) ramps, but the boat usually centers itself with a little driving and never caused the fender to push in like that. I would contact your nearest dealer to have them look at it. Ramlin is based out of Florida - you might be close enough to take it directly to them.
    jmo
    2018 Ski Nautique 200 TE, H6
    • pipester101
      • Jul 2007
      • 34
      • Orlando, FL
      It was rubbing against the fender which i thought the rails would prevent this from happening..
      Anyways i took it down to SouthEast Correct Craft and they said i have something else going on??? I bought the boat and trailer from there and i am only about 3 miles from them.
