Bent Tracking Fin
  • GroovyNautique
    • Oct 2006
    • 77
    • Calgary, Alberta, Canada
    Bent Tracking Fin
    One of my tracking fins on my 93 SN is a little bit awry. Am I safe to try and bend it back some how? Any suggestions on how I should be doing this safely without compromising anything else?
    Thanks!
  • 81nautique
    • Feb 2006
    • 257
    • Big Rock, Illinois
    • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
    RE: Bent Tracking Fin
    Remove it and put it in a vise, a little heat and you can tap it back to shape if it's not too bad to begin with. Otherwise bring it to a prop shop and they'll fix it right up if your not comfortable doing it yourself.
    • jos
      • 154
      • Netherlands Boxtel
      No heat
      Use no heat.
      Only specialists may use heat due to long time experience.
      There is only a smal window where the heat bending can be succesfull.
      As its crashed cold it also can be bend back cold.
