Changing Starter on '05 ZR6 SV-211
  • dabigkahuna
    • Sep 2004
    • 125
    All I can say is trying to change this starter makes me want to get rid of this boat! I cannot believe it is this difficult to change a starter; I must be doing something really stupid.
    Anyone changed a ZR6 starter in a '05 SV-211 Team Edition? Did you take out the port ballast tank to get better access? I'm only 168 lbs. and I'm pretty skinny, but I couldn't even get to the inboard mounting bolt without doing some really gnarly fetal position yoga stuff. Then, once I got the ratchet on it, I have like 4 inches to move the wrench with absolutely no leverage, so it's still on there...I'm seriously going mad on this one, somebody please tell me there is an easier way!
    :evil:
  • dabigkahuna
    • Sep 2004
    • 125
    RE: Changing Starter on
    I got the outboard bolt off, but the inboard bolt is another story. I think I may just remove the port ballast tank so that my shoulder isn't at such a painfull angle when trying to get to it. Anyone got any simple solutions to replacing the starter?
    • wakeboard69
      • Mar 2007
      • 22
      • UK
      Dude, I have a ZR6 in an 'o4 SANTE. Diff boat I know but same pain in the ***! I removed the back seat totally so I could first lie on my stomach and get a number of extensions on the socket set so I could get a long bar to swing right underneath the sump - it is very tight and you will have to play about with all sorts of extensions to get it just right. Once it is moving a little bit you can then change position and reach through where the back seat was and down the side of the gearbox to get access to the bolt. This will give you a much easier access to get it off quickly. Be patient, you will find you get very very little movement to start with. Spray loads of 3in1 all over it/bolt. It took me and a mate over three hours to get mine off - try not to get frustrated with it. I've just got the boat second hand and the starter went pop second time in the water. Not happy with that privaste seller!!
      • dabigkahuna
        • Sep 2004
        • 125
        hahaha!!! I'm glad I'm not the only one ****-bent on this **** starter. Thanks for the info., I really thought it was me, but it's just a real pain in the arse!!
        Aloha!
        • boatech
          • Aug 2006
          • 247
          i feal ur pain im 6-1 240# think about my big butt trying to get in there. my advice breath slow and relax you will get it, and oh yeah cooler full of beer for after you earned it!!!!
          • surfdh74
            • May 2006
            • 75
            • DeBary,Florida
            warranty issue
            is this not a warranty problem. I believe my starter just went out? I have an 05 SV-211 Team with 200 hrs. Thought it was the batts but replaced them and it still does not turn over just a clicking sound?
            • Roy
              • Jun 2005
              • 28
              RE: warranty issue
              Hello surfdh74,
              Could be a starter relay, PCM part number R130001.
              Good Luck,
              Roy
              • Roy
                • Jun 2005
                • 28
                RE: warranty issue
                Hey, sorry, my bad, there is no R130001 on your year engine. Call your dealer, could be warranty.
                Thanks,
                Roy
                • surfdh74
                  • May 2006
                  • 75
                  • DeBary,Florida
                  RE: warranty issue
                  Thanks Roy..dropped it off at Southeastcorrectcraft this morning!!! They are on it!!! I need my boat running!!!!! Alright thanks later!!!
