on an 04 210 san is it normal for the bildge to come on automaticaly while wakeboarding for only about an hour. it runs for about 2o-30 seconds.
Tags: None
RE: bilge water
that seems too often....but unless you have a dripless coupling for where the shaft goes thru the hull, then it's normal for some water to drip in to lubricate the shaft... take a look at it, if it drips more than once every 3-6 seconds, then you need to tighten it...How 'bout a little reverse action...
