I have a 06 206 Team with the 330 Excaliber 68hrs. Last weekend I was getting a Low Oil Alarm. I checked the oil and the oil level on the dip stick was correct. Both the Analog and Digital guages will hunt matching each other at idel from 40 psi to down to 15psi. At high RPM's the oil pressue is close to 58psi on both the digital and analog guages. The alarm appears to be working properly at the low oil pressure alarm point. I am planning on putting a mechanical oil psi guage at the sending unit area to verify that the oil pump is operating correctly. I am wondering if the oil pressure sending unit is failing or have there been issues with the oil pressure sending unit? I am in New Mexico and the closest dealer is approx. 7hrs away. I'm trying to rule out any options before I have to take it back to Texas.
Thanks in advance for any input.
Steven :shock:
Steven :shock:
