I am getting frustrated. My low hour sweety is not starting. After a carb rebuild that left it flooding due to float settings in the secondary bowl, since has been corrected, now it wont run below mid throttle and will only start after a shot of starting fluid (I know, not good). I've adjusted the floats to allow slightly more than normal fuel levels in both bowls of the Holley. The clear bypass hose on the fuel pump shows no fuel. Could it still be a bad pump if it runs at higher RPM but won't idle? There is fuel in both bowls when I pull the carb off to check the floats. I can't really afford a large repair bill right now but want to get some more hours on the clock soon. Any suggestions out there. Any would be appreciated. Thanks.
Gary
Gary
