Please Help...Engine oddity
  • joelhern2
    • Sep 2005
    • 158
    • Cincinnati,OH
    This past weekend my "Oil" light would flash and the alarm would beep a few times and then go away (seemed to beep and flach 2-3 times and then stop).
    Also, every time I slowed down to pick-up the rider black smoke would start coming out of the stern of the boat.
    Any ideas? I checked the oil level...that was good. I checked the engine temperature...that was good.
    \'91 Barefoot Nautique
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Please Help...Engine oddity
    Black smoke is to much gas. If you RPM is falling or the engine is not running well I think as the rpm's drop the oil pressure does also. I would try a tune up Water Dryer in the gas, and a new fuel filter. If that doesn't do it I would do a tune up. When you pull a spark plug are the light brown or black on the tips If black you may have a spark problem.
    Nautiqueless in San Diego
    • boatech
      • Aug 2006
      • 247
      SOUNDS LIIKE A CARB ISSUE
