Tachometer Adjustment
  • WylieNautique
    • Aug 2007
    • 19
    • Wylie, Texas
    Can the tachometer be adjusted to zero? My 96 Ski Nautique 196 shows about 400 rpms when the ignition is turned on but the engine has not been started. I have not pulled the gauge console out yet to look for an adjustment. Just curious if anyone knows. I don't want to go through the task if there is no way to adjust to zero.
    1996 Ski Nautique
    GT-40
  • skijones
    • Mar 2005
    • 235
    • COLUMBUS OH
    • 1985 2001 1999 Snob
    RE: Tachometer Adjustment
    My 99 snob has the same problem. Don't know if there is an adjustment, but would also like to know.
    • WylieNautique
      • Aug 2007
      • 19
      • Wylie, Texas
      I went ahead and pulled the gauge console and there is a calibration adjustment on the rear of the tach. Have zeroed mine. Will know if I have really corrected problem the next time I go out. :grin:
      1996 Ski Nautique
      GT-40
      • gtxragtop
        • Oct 2011
        • 56
        • Worcester
        How do you know that it is reading correctly now? Perhaps the original adjustment was correct?
        • gtxragtop
          • Oct 2011
          • 56
          • Worcester
          Tach Troubleshooting Faria Instruments
          Review this document I found: http://faria-instruments.com/site_ma...achometers.pdf
          • BT
            • Dec 2008
            • 77
            • Alabama
            • 2012 Super Air 230 1997 Super Sport sold
            My 97 Super Sport tach varied by as much as 500 rpms at times. It was very intermittent. I replaced the tach and it corrected the problem for a couple of years then it started doing it again. I never looked into it, but I suspect it is a problem with a wiring connection. The grounds for the gauges are piggybacked onto one another and are prone to work loose. I fixed my temp gauge a few times just by tightening connections.
            There is an adjustment on the rear of the tach.
