Can the tachometer be adjusted to zero? My 96 Ski Nautique 196 shows about 400 rpms when the ignition is turned on but the engine has not been started. I have not pulled the gauge console out yet to look for an adjustment. Just curious if anyone knows. I don't want to go through the task if there is no way to adjust to zero.
Tach Troubleshooting Faria Instruments
Originally posted by WylieNautique View PostI went ahead and pulled the gauge console and there is a calibration adjustment on the rear of the tach. Have zeroed mine. Will know if I have really corrected problem the next time I go out. :grin:
My 97 Super Sport tach varied by as much as 500 rpms at times. It was very intermittent. I replaced the tach and it corrected the problem for a couple of years then it started doing it again. I never looked into it, but I suspect it is a problem with a wiring connection. The grounds for the gauges are piggybacked onto one another and are prone to work loose. I fixed my temp gauge a few times just by tightening connections.
There is an adjustment on the rear of the tach.
