Or what other bulb from the auto store will work???
Tags: None
RE: Docking lights part number for the bulb????
***Update from Correct Craft
There isnt a part number, you have to replace the entire unit.
Burned out docking light
You do not have to buy a new light from Correct Craft. We had a light burn out also. Go to a Lowes or Home Depot and go to the landscaping light section. All it is, is a simple halogen 12 volt bulb. It comes packaged with the reflector. That is what we used and is was a perfect fit. Hope this helps
Dan, the STS Man
RE: Burned out docking light
Did not know that. Well CC emailed me and said the entire unit needs to be replaced under warranty. I will def try the lowes idea. Thanks!
This was my response from CC:
Hello Ryan,
Let your dealer know you will need the whole light replaced.
It should be under the warranty.
Let me know if the dealer need's to call me about this.
Hope this will help you out.
Best Regards
Correct Craft Inc.
Customer Service
(407)855-4141
www.correctcraft.com
