Where is the Ignition Fuse
  • shasnon
    • Aug 2007
    • 1
    Got in a hurry replacing my battery and reversed bias it. Now the engine will not start, starter is getting no juice. Everything else works except the stereo. I reset the main ckt bkr, red button. Where is the ignition fuse on a 2003 Ski Nautique 196?
    Excalibur Engine 350 ci 330 HP Model # PLA PRR 12M
    Welcome any other hints?
    Steve
  • Red57Bird
    • Aug 2007
    • 381
    • Raleigh, NC/Lake Gaston
    • 2003 Super Air
    The facotry manual states that reversing polarity when reconnecting the battery will permanently damage the keyless ignition control panel and the swithc control box. Below is the text from the manual:
    CAUTION: The keypad and switch control box will be damaged beyond repair if the boat battery cables or the main power leads to the keypad and switch control box are reversed. Be sure to use caution and avoid reversing these connections.
    2003 SAN (current)
    2003 Chaparral 220 SSi (sold)
