has anyone ever heard of water leaking in from under the rub rail? I have an 04 san and cant figure wher the water is comming from! If I shove my hand up under the port side of the interior from the wrap arround seat the carpet is all wet . And what is up with the two vents on the back of the boat on either side. on one side there is a blower hose on the othe side is a wide open space to the starbord storage locker. i have already filled the boat full of water on trailer and no leaks, had rudder and hard ware all replaced , ballast tanks dont leak stay full all day, dripless packing, shut main valves for ballast during use. If any one have any suggestions thank you ![/b]
Tags: None
RE: too much water in boat
I have heard of a couple of boats that have leaked at the hull/deck attachment point. Have your dealer take a look and repair it under warranty.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I had that problem on my '05 210. Water was coming in under the rub rail on the port side when I made left hand turns (especially when the ballast was full). I took it into the dealer and they repaired it under warranty. They went ahead and resealed the rub rail all the way around.Current: 2017 G23
