Installing original ballast in a 236 Limited
  • Laptom
    • Oct 2003
    • 876
    • Eindhoven, Netherlands
    How difficult is to install the original ballast tanks in a 236 Limited? I know (imagine) the 2 rear tanks are not a problem. But the belly tank could be. Or is it just remove the petrol tank and move the ballast tank to the front?
    Jeff, could you provide some pictures for me perhaps?
    Tom
  • BigRob
    • 15
    RE: Installing original ballast in a 236 Limited
    you should be able to remove the fuel tank and slide the new one in no problem , i havent looked at the 236 lately
    but it should be similiar to the 211, new 210's( new 210 has 2 tanks you slide them in one at a time.)
    if the bilge pump is near the fuel tank you will have to remove it to get the tank to clear.
