hot water shower install??
  • crghou
    • Jun 2007
    • 86
    • Houston
    • 2003 SAN 210 Team
    what would be the best way to get a hot water shower in my boat? I know on the dash there is a button for it, but how hard is it to put one in, what is needed and how do you do it?
    2003 san210 team.
    thanks
    chris
  • AirJeff
    • Jul 2004
    • 168
    • White Bear Lake, MN
    I installed one in my '02 air a couple years back. It was not hard, but did take a little while to get all the hoses routed and looking nice. I bought the shower from www.go2marine.com. The wires were back in the engine compartment where the pump would have been installed. I just hooked up to those wires, ran the hoses and installed the control valves. I don't have all my pics here, but here is one of the valves installed in the trunk.
    Jeff
    2002 Air Nautique (DD)
    GT-40
    • crghou
      • Jun 2007
      • 86
      • Houston
      • 2003 SAN 210 Team
      you dont have a parts list or write up or know of anyone do you?
      • AirJeff
        • Jul 2004
        • 168
        I'm pretty sure there was one somewhere on here. Search for shower install and you should find it. Parts were pretty minimal, here is a quick list of what I remember.
        -Aquatik shower (aka HeaterCraft) (includes shower, hose, and control valves)
        -extra hose if you need it (I needed extra hot and cold hose, but I have a DD)
        -I put a brass ball valve on the engine block for the hot hose, that way I could turn it off if needed (you could do that on the cold side also. now that I think of it, I think I will)
        -I needed a block to mount the pump on, you might not since you have a 210
        -misc stainless fasteners/screws (what you will need will depend on your install)
        -I think I used a couple of marine grade wire couplers to wire in the pump (crimp connectors with adhesive shrink tubing)
        If you can't find the write-up let me know and I'll see if I can do a quick one.
        One last note, if you need any extra parts/hose for the shower the guys at HeaterCraft are great to work with. I wanted the flush mount valves so they exchanged them for me. :grin:
        Jeff
        GT-40
        • crghou
          • Jun 2007
          • 86
          • Houston
          • 2003 SAN 210 Team
          if you could maybe come up with a parts list and a quick run down of how you did everything that would be great. How much did it cost you?
          And where i would find all the wires and how to hook it all up.
          thanks
