Stock prop on 2007 210?
  • aarond0083
    • Aug 2006
    • 686
    • Triangle, NC
    Anyone know off hand what the stock prop is on the new 210? I put a small ding in mine this weekend due to low water at the launch ramp. I think I may go with a higher pitch and get my stock one repaired but would like to use the same brand.
    Previous Nautiques
    2012 210
    2009 210
    2007 210
    2004 210
  • DERRICKHWC
    • Oct 2006
    • 58
    • HOUSTON, TX
    RE: Stock prop on 2007 210?
    stock prop is an acme
    if you have a signiture or limited it is acme prop 381
    team prop is acme 645
    power prom is 1465
    • aarond0083
      • Aug 2006
      • 686
      • Triangle, NC
      Thanks. I have a Team so it must be Acme 645. I hadn't had a chance to pull it off and really look at it yet. Would you recommend a different pitch than the 645 if you run additional ballast over stock? Typically I run 480 lbs. plus stock but occasionally will fill two more sacs for a total approx 1100 plus stock. I would rather have better hole shot than top speed.
      Previous Nautiques
      2012 210
      2009 210
      2007 210
      2004 210
