05 TE SV-211..... Three speed heater, only one speed is working? 200 hours on the boat. Used the heater maybe 5 times(live in Florida). Has anyone had a problem with this? Thanks Later!!!!
RE: Three speed heater
I think you should have a rele in the breaker box connected to a set of resistors.
In my opinion you should have a problem with the resistors.
If true you should only have the higher fan speed (no resistance)
Can you disconnect the fan?
How many times can you push the button before it turns off ? (should be four)
It can be also a problem with the rele.
Good luck!
