No stern eyes on 206
  • jjackkrash
    • May 2007
    • 498
    • PacNW
    • 2021 Ski
    I have an 03 SN 206 that did not come with stern eyes. I have never seen a boat without them and there does not appear to be any way to strap the stern to the trailer when towing (which is required in many states). Is there a reason CC would not put stern eyes on a 206, or is this simply an ommission from the factory? Its not hard to add them, but I was just wondering if there was any reason not to add them. Also, is there another point from which to strap the stern to the trailer that I am missing?
    Thanks,
    Jack
  • wakecrashin
    • May 2007
    • 376
    RE: No stern eyes on 206
    None on an 07 210 either
    • mathews01
      • Oct 2006
      • 38
      • MN
      Try strapping down your boat to the trailer by using the swim platform brackets - I do that on my 206 and it works great.
      2007 SN 206
      • MarkP
        • Sep 2003
        • 155
        • Rochester Pennsylvania
        You can see mine 2004 never seen one without.
        2004 Ski 206 Limited,Midnight Blue and Black,
        Silver Accents,330 Excalibur,Perfect Pass.
        Nautiques Rock!! My 2004 206
        • Quinner
          • Apr 2004
          • 2246
          • Unknown
          • Correct Crafts
          Strap to the grab rails or the lifting ring. If there is enough force too make either fail the least of your worries is the tie downs.
          • todda
            • Jan 2005
            • 281
            • Granite Falls, WA
            • 1999 SNOB
            My 99 196 SNOB doesn't have them either. I too use the swim platform bracket to strap mine down, and it has worked w/o fail.
            Todd
            Todd Aalbu
            1999 SNOB
            66.5" HO S2
            • pipester101
              • Jul 2007
              • 34
              • Orlando, FL
              I asked the same question. I just used brackets under the platform.
              • jjackkrash
                • May 2007
                • 498
                • PacNW
                • 2021 Ski
                Thanks! Its my first CC. I'll use the swim-platform brackets.
                Jack
                • ag4ever
                  • Feb 2004
                  • 1180
                  I would not use the grab rail, but the swim platform is attached just as well as the lifting rings, and is just as strong.
                  • SquamInboards
                    • Sep 2005
                    • 397
                    • Squam Lake, NH
                    • '82 2001 '84 2001 '86 2001 '98 NSS '87 American Skier
                    you can also use a long strap that goes over the whole boat, and just wrap some rags or carpet on the parts where it touches the hull so it doesn't scratch... lots of smaller boats do this, though it's not quite as good as two transom tie-downs...
                    How 'bout a little reverse action...
                    • J
                      • Aug 2007
                      • 80
                      • BC Interior
                      my 226 doesn't have em either.....i us the swim platform brackets..........a person could install a couple if they use their trailer alot i guess.....
                        I have a 1997 Ski. I use the lifting eye for the attachment points for the tie downs. The eyes on the trailer are spread out wide, and the straps of the tie down go to the outside at about a 45 degree angle, just outside of the platform brackets, and above the speedometer pitots on each side.
                        I would not use the hand rail grab for the tie down, they are designed for a person to pull their self on to the platform, not for heavy loads.
                          • todda
                            • Jan 2005
                            • 281
                            • Granite Falls, WA
                            • 1999 SNOB
                            Beautiful boat as your "first" CC! Congrats on a great purchase!
                            Todd
                            Todd Aalbu
                            1999 SNOB
                            66.5" HO S2
