Battery Switch (Perko or Blue Sea)
  • mf01
    • Jun 2005
    • 515
    • Austin, TX
    I need a battery switch for my boat and I have a local West Marine. I have seen Perko's before, but I just saw another brand, Blue Sea. The Blue Sea got good reviews and looks like it can handle more power:
    http://www.westmarine.com/webapp/wcs...;classNum=null
    Or there is the Perko:
    The disconnect version for the Blue Sea is about $10 cheaper. I don't currently have 2 batteries but I would get the 2 battery switch. Is there any reason I shouldn't get the Blue Sea? Thanks.
    Previous:
    2011 Super Air Nautique 210
    1994 Sport Nautique
  • JAG
    • Jun 2005
    • 98
    Battery Switch
    I have the Blue Sea installed in my 90 and have had absolulety no problems with it. It was cheaper and more compact then the Perko.
    • Grant_West
      • 758
      • Redwoodcity Ca
      I have used a few Blue Sea's products and I like them. I have a Blue Sea battery switcher in my boat and I like it better than the Perko. It seems to rotate smoother and it glows in the dark and just feels more finished. I have also used the Blue Sea battery combiner Its a awesome product. You should look into it. IMO the battery combiner will make it so you dont need a battery switcher
      Weird thing is My current Blue Sea battery switch went bad. Yup my boat was having a hard time starting and I traced it back to the switcher. I took it out and West Marine switched it out no problem. I have never heard of a battery switcher going bad I would think they are very simple and that would be one thing that would not break or go bad.
      Here is a Before and After Pic of the Battery install I did using the Blue Sea battery combiner.
      • Grant_West
        • 758
        • Redwoodcity Ca
        after. The battery combiner is the black box on the wall
        • mf01
          • Jun 2005
          • 515
          • Austin, TX
          I stopped by Academy sports at lunch and picked one up for $24, a little cheaper than West Marine ($34). Here's the model I got: http://bluesea.com/category/1/products/9001e
          I just need to figure out the cabling. I have some extra 4 Gauge from my stereo install, so I might use that to connect the switch to the battery. I'd just need terminals for it and I couldn't find any 4 Gauge at Academy.
          Previous:
          1994 Sport Nautique
          • JAG
            • Jun 2005
            • 98
            Battery Switch
            West Marine usually carries several sizes of battery cable lugs
            • MHayes
              • Aug 2004
              • 830
              • Roswell, GA
              RE: Battery Switch
              Are those pictures in your pontoon boat Grant? What does the system look like that you have in there?
              2001 Air Nautique
              • Grant_West
                • 758
                • Redwoodcity Ca
                M-Hays. Yes Thats the battery/engine compartment in our Pontoon boat.
                nothing special. 4 W7's and 8 6-1/2's :grin:
