Replacing t-stat gasket
  • wrmann
    • Oct 2005
    • 5
    I posted this question in a larger question earlier today but here it is again. I had to check my t-stat this weekend when my SN started to overheat. The old gasket was cemented on both sides. When I replaced it, after carefully cleaning both surfaces i didn't use any gasket cement. During instalation I ripped the new gasket so I have to install another gasket next weekend. Should I use gasket cement when i install the new one? Do I use cement on both sides of the gasket?
    Thanks.
  • Hollywood
    • Sep 2003
    • 1930
    • WIIL
    Re: Replacing t-stat gasket
    No, you shouldn't need any.
      RE: Re: Replacing t-stat gasket
      You might also consider gasket cement to hold the gasket on one side, so you do not damage the next one.
      • SquamInboards
        • Sep 2005
        • 397
        • Squam Lake, NH
        • '82 2001 '84 2001 '86 2001 '98 NSS '87 American Skier
        I'm with Hollywood, it's not very hard to install and you shouldn't need any cement.
        How 'bout a little reverse action...
        • TRBenj
          • 1681
          • NWCT
          Re: RE: Re: Replacing t-stat gasket
          Instead of gasket cement, 3M all purpose spray adhesive works well to hold gaskets in place while youre tightening the bolts. I used this on all my gaskets.
          1990 Ski Nautique
          NWCT
          • Rick
            • Mar 2004
            • 1250
            • San Diego, Ca
            RE: Re: RE: Re: Replacing t-stat gasket
            Your don't need to use sealant with the gasket. Having said that I always use a thin layer of the blue sealant (3M) to hold the gasket in place. By thin I mean spread on like glue just enough to hold it down. I then use the same amount on the top. The gasket is really enough but you have had to do it twice now and I would bet you don't want to do it again. The sealant will noe harm the gasket.
            Nautiqueless in San Diego
            • Hollywood
              • Sep 2003
              • 1930
              • WIIL
              There is little to no chance of being able to reuse a paper gasket once you've smeared that crap all over it.
              • Rick
                • Mar 2004
                • 1250
                • San Diego, Ca
                I agree with Hollywoods comment about reuse. However what is your time worth. I would never reuse a $2.00 gasket at the expense of having to do it all over again if it leaked.
                • Andrew
                  • Aug 2005
                  • 891
                  • Tuscaloosa, AL
                  i always dab a little permatex on there to keep it in place..........
