Transmission Oil
  • mfennig
    • Jun 2007
    • 11
    Transmission Oil
    What oil should I use on a 94 SN with the PCM transmission??
    RE: Transmission Oil
    There should be a tag on the top of your transmission.
    Look in your owners manual.
    If you do not have an owners manual, contact Correct Craft
    • TRBenj
      • May 2005
      • 1681
      • NWCT
      Conventional Dexron/Mercon ATF. I prefer Valvoline.
      Do NOT use synthetic!
      1990 Ski Nautique
      NWCT
      • SquamInboards
        • Sep 2005
        • 397
        • Squam Lake, NH
        • '82 2001 '84 2001 '86 2001 '98 NSS '87 American Skier
        Should probably be Dexron like most other PCM trannys
        How 'bout a little reverse action...
        • darrel409
          • Jul 2004
          • 566
          • San Dimas, So. Cal
          Whats in it now, oil or ATF?
          • 93Euro
            • Feb 2006
            • 94
            • California
            • 2006 air nautique 210 SE
            Re: RE: Transmission Oil
            Why not?
            • TRBenj
              • May 2005
              • 1681
              • NWCT
              Why not?
              Because its too slippery for wet clutch transmissions. PCM was seeing failures around 800-900 hrs when synthetic was used in the tranny. Stick with conventional.
              1990 Ski Nautique
              NWCT
