Re: RE: Re: RE: Re: RE: Re: RE: Re: RE:
That should fill the block just fine- especially if you drain everything (block, manifolds, cooler, elbow, etc). As long as you drain the water first, it really shouldnt matter if you fill it warm or cold.
Then again, is it much easier to draw in from a hose than to pour it in by hand? Its only 1 hose clamp, and I like the RWP to be removed anyways. I dont think its good to have antifreeze sitting in the strainer either (I remove that as well).
