Perfect Pass screen blank or scrambled
  • rickharp
    • Dec 2004
    • 70
    • Jupiter, FL
    • 2014 210 and 2013 200CB
    i keep the boat in a covered boat house, never squirt the dash, keep the boat covered with full cover. 07' 211te, dewpoint 69, temp 75, 150 hours, this morning, the pp screen first showed some giberish, then went blank, no pixels at all. restarted it a couple times, it appears to work ok, but no screen. about an hour later, i start to see some lines, then some faint see through to the correct screen, then slowly it came back on to normal contrast. one would think it was moisture, but there was no previous actions that would suggest it.
    anyone else experience this. or is there an existing thread on the subject. is it a known problem. thanks
  • Batman
    • Jan 2005
    • 186
    • Kingsport, TN
    RE: Perfect Pass screen blank or scrambled
    check the ground wire. Had similar instance and that was the problem
    If you don\'t do it today, you will be one day older when you do!!
