Alignment of Water pump pulley
  • slalomdude
    • Jun 2005
    • 108
    The belts on my GT40 have been leaving a lot of dust in the engine. Looks like they may be too loose. I also noticed that the water pump pulley is out of alignment with crank pulley.Any ideas on how to line it up?
    Also the oil pressure gauge pegs out to 80 psi, even at idle, and never drops until I shut it off. I was suspecting a short on the wiring, not sure if the sending unit has ever been replaced.
  • jedgell
    • 170
    • Bozeman, MT
    • 2004 SN 196
    RE: Alignment of Water pump pulley
    I've noticed the same thing with my water pump, way out of allignment. My belts are 12 years old and have 400 hrs on them so it can't be that bad, but I'd think that it has to be harder on the bearings.
    \'95 SN Signature Ed.
    GT-40
    PP Stargaze
    **For Sale**
    • richard
      • Feb 2005
      • 406
      • HK
      in most case,the curpit is the rusted pullys.for long term,change all the pullys with aluminum made.this will secure belts long life and no dust come out
        The raw water pump does not an extreme amount of torque to turn it. If you really pry the pump hard away from the block when you are tightening the belt, it will pull the pulley out of alignment. You can also polish the grooves of the pulley with a wire brush and get some of the rust off the pulley. Opening your engine cover and letting the compartment dry out might help the pulleys not rust as much.
        • TRBenj
          • 1681
          • NWCT
          Re: RE: Alignment of Water pump pulley
          I have to put a good amount of pressure on the pump to bring it into alignment, as well as get the proper belt tension. You can easily tighten up the pump when its not aligned- play around with it.
          1990 Ski Nautique
          NWCT
          • Hollywood
            • Sep 2003
            • 1930
            • WIIL
            It looks as though the RWP pulley is about one belt thickness aft the crank pulley on our '88. It's been like this all year, and possibly subsequent years without any problems. Next season when it goes back on I will try to get it properly aligned with a few washers.
            • boatech
              • Aug 2006
              • 247
              rich nailed it. this is all you need to know right here. you will need to sand and paint your pulleys or go aluminum. the rust acts like sand paper and is sanding your belts down thats why you see black dust. it makes the belt drop down into the grove of the pulley wich makes it losen as well you can tighten it all you want but if you do not address the pulleys it will just sand them away until they break. its a very common problem.
              • slalomdude
                • Jun 2005
                • 108
                Thanks, any suggestions for type/brand of paint.
                • boatech
                  • Aug 2006
                  • 247
                  RE: Re: RE: Alignment of Water pump pulley
                  ive used krylon and rustoleum both worked fine. just figure on doing it every 1 1/2 -2yrs depending on climate/conditions. if in salt dont waste your time just pony up for the alum. oh semigloss btw.
                  • boatech
                    • Aug 2006
                    • 247
                    thats asking to be stranded!! you better have a spare your gona need it!!! $12.00 belt ruin your day .
