OK here's a really dumb question - I've got a 96 Nautique with the Ford GT40 EFI motor. Where the heck is the impeller located so I can change it?
I'm running hot at slow speeds. When I go faster the temp drops right back down to normal. I'm assuming this is an impeller problem. I've checked the strainer and it's clean. So is the water intake. Any ideas?
