I recently purchased my first nautique ( 07, 220), and up untill late no problems. I have recently had a gateway replaced after loosing power to all my guages. Once the new gateway was replaced i had power to all my guages excluding Tacho, Speedo, temp, and perfect pass. After taking thew boat back again to the dealer and 2 weeks in the shop they discovered that there was a wiring fault between the ECU and the gateway.
After getting the boat back I took the boat out over the weekend with all guages working ,as i went over the wake of another boat the perfect pass disengaged and the speedo stopped working.
If i then speed the boat up and then backed off the power the speedo and perfect pass will renguage for a few seconds and then stop working again.
Has anyone had a similar problem ?
Can anyone give me any advise as to what the potential problem could be ?
I have spoke with the agent again, and he said he thinks it may be either the lanyard or the guages ? I disagree and think its some type of wiring problem.
However i am no expert
This whole senario has been taking place for the past 6 weeks and is absolultely driving me nuts !!
Any advise or help would be greatly appreciated
