Battery drain
  • slalomdude
    • Jun 2005
    • 108
    Battery drain
    after leaving the boat for 10 days, the battery went flat. I checked the amp draw with everthing off and the keypad locked. The draw was 0.176 amps. this is obviously too much and was looking for ideas where to start looking ,or any usual culprits. I have a 2000 ski with stock cassette radio, no amps etc.
  • AirTool
    • 4049
    • Katy, Texas
    RE: Battery drain
    Maybe start taking fuses out one-by-one with your ammeter hooked up.
    • Andrew
      • Aug 2005
      • 891
      • Tuscaloosa, AL
      RE: Battery drain
      or just check the draw at the fusebox
      • Rick
        • Mar 2004
        • 1250
        • San Diego, Ca
        RE: Battery drain
        Perfect pass, the back lighting on the stereo, and your bilge pump may run every 2 minutes for 2 seconds to check for water. You need to put a shutoff switch on the battery or get a trickle charger from Pep boys and leave it plugged in.
        Nautiqueless in San Diego
        • Jubers
          • May 2007
          • 11
          RE: Battery drain
          I have the same issue. Happens even with the bilge turned off. I suspect it is another defect associated with the "Smart Pod". I just disconnect my battery when I pull my boat.
          • skiswm
            • Mar 2005
            • 165
            • SF Bay Area/Truckee CA
            RE: Battery drain
            My drain has always been the stereo, I finally just started to undo the cable to the battery for it. No matter what I did, it'd always drain.
            • Christopher-W.-Becker
              • Dec 2003
              • 168
              • Ann Arbor, MI
              RE: Battery drain
              All I have a 2004 STOCK 216 LE. With the the switch in off the batter lasted over six months last winter (yeah I know, dont leave the battery connected over the winter, but I got busy and forgot). She started first try this spring....So she did not have much of a drain.
              Christopher W. Becker
              9323 Mockingbird Ln
              Saline, MI 48176
              cwbecker@umich.edu
              • Andrew
                • Aug 2005
                • 891
                • Tuscaloosa, AL
                Re: RE: Battery drain
                yeah, the headunit will always pull power so that it can keep the preset stations and the clock up to date.......
                slalomdude, this is most likely ur problem. i woulda mentioned it sooner, but i didn't even think about it.....
                the easiest solution is a switch.... whether it be on the radios power circuit or at the battery...............
                • dwsa
                  • Sep 2005
                  • 134
                  RE: Re: RE: Battery drain
                  Does the 176 mA drop if you remove the output of the alternator?? If so, its your alternator, usually the rectifier leaking.
                  • slalomdude
                    • Jun 2005
                    • 108
                    Re: RE: Re: RE: Battery drain
                    Thanks, I will check it. Although the amp draw is measured across the inline fuse on the #12 wire that only feeds up to the dash and accesories. All power to the alternator goes thru the main powerlead from the battery, doesnt it?
                    • M3Fan
                      • 1034
                      RE: Re: RE: Re: RE: Battery drain
                      The later smartpod boats had a switch which has 3 positions- all off, all on, or autobilge only. This is because the smartpod always draws power. It's a 3 way toggle under the dash. My boat had it added as a retrofit and I couldn't imagine going without it.
                      2000 Ski Nautique GT-40
                      2016 SN 200 H5
                      www.Fifteenoff.com
                      • Jubers
                        • May 2007
                        • 11
                        Who did your retrofit? I'd like to add that to mine. My stereo has been disconnected for years so I knew that wasn't my issue.
                        • jmo
                          • Mar 2006
                          • 710
                          • MA
                          slalomdude - how old is your battery? If its the original its probably time to replace it. Batteries live in cars is 4-5 years, not sure what effect the marine usage does to the lifespan, my guess is with all the starting and stopping it's harder on it.
                          I've left mine in the garage with just the auto-bilge only on for several weeks without an issue.
                          jmo
                          2018 Ski Nautique 200 TE, H6
                          • slalomdude
                            • Jun 2005
                            • 108
                            The battery was replaced last year. That retrofit for the 3 position switch looks like a great idea. Anyone know where they are available?
                            • dwsa
                              • Sep 2005
                              • 134
                              The orange wire from the alternator output connects directly to the battery, so if your alternator is bad or partly bad (leaky diodes) it will drain the battery. You can try disconnecting the battery while the engine is running, it should keep going, if it dies then the alternator is putting out nothing. If it still runs you could still have a partially shorted rectifier pack, only way to be sure is to measure the inline current in that orange wire on alternator, engine off, there should be zero current. Or measure the current draw from the battery. I have noticed a small spark when I connect my battery, I can only think this is the keyless ignition cct, as nothing else is on. Good luck.
