SANTE 03 ballast system switches malfunction - pls help
  • aaron
    • Feb 2025
    • 114
    • Malaysia
    hi guys, the switches on the console panel to activate pumping in and pumping out are lit and /or flashing when depressed but the pumps dont seem to be acitivated,(not getting any current)I hv checked the pumps and they are working when directly connected to a power source.
    Fuses are fine as well...obviously something electronic.Can someone lead me to a solution?or to a websource where i can get the wiring diagram for the boat.
  • Mark56
    • Jul 2007
    • 36
    • AU
    2006 model sv211 same prob
    have the exact same problem with my 211 also lost the radio cannot work out why ,come back from dealer after fixing other fault this way. if you work it out love to know
    • James
      • May 2007
      • 151
      • Indian Wells, CA
      RE: 2006 model sv211 same prob
      I had a similar problem with one of the pumps on my '06 216. The dash pod indicator lights on the pump switch worked fine but there was no power at the pump. It was fixed under warranty.
      The dealer said there was a bad conection in the wiring at a plastic "plug in" connector between the dash pod and the pump. I am not sure where the connector is located. Good Luck.
      • Mark56
        • Jul 2007
        • 36
        • AU
        The problem has been fixed on my sv211 it being a connector block on the port side behind speaker coming apart it also supplied power to the radio hope helps
        • Daytomann
          • Mar 2005
          • 211
          • Oklahoma City, OK.
          Having this same problem for my Starboard drain pump. Any more info on this?
