damaged brass block drain plug, suggestions?
  • TRBenj
    • 1681
    • NWCT
    Doug, thats pouring it in. Block is drained first, of course.
    Brad, not sure what to tell you. My '90 would take closer to 3.5-4 gallons before the A/F would get past the riser. I could hear it draining into the fiberglass invertaflow muffler. On the Tique (302) I actually raised the front of the trailer up quite a bit after backfilling, and only a cup or so of A/F trickled out of the exhaust pipes. Are you draining the block first before backfilling? If so, do you raise the hose above engine height when pouring it in?
    1990 Ski Nautique
    NWCT
    • bchesley
      • Feb 2006
      • 1252
      • Tyler, Texas
      Yes I drained it. I leave the motor sitting level and I take the hose from the raw water pump and hold it as high as I could. It was at least two feet above the motor when I was pouring it in. Not quite sure where its all going. I am pretty confident in our frigid Texas winters that I should be fine.
      2001 Super Air Nautique
      Python Powered
      100 Amp Alternator
      Dual Batteries
      Many upgrades coming...
      • east tx skier
        • 1561
        • Tyler, TX
        High of 62 today. 72 tomorrow. Brrrrr :grin:
        • TRBenj
          • 1681
          • NWCT
          Im on a level surface in the garage, too. Strange.
          Since you drained the block, Im sure youre more than protected. Want to trade weather, by the way? We got 2" of snow yesterday.
          1990 Ski Nautique
          NWCT
          • Miljack
            • Dec 2004
            • 1616
            • Charlotte, NC
            • '08 230 TE ZR6
            Andrew,
            I used your drill it perpendicular to the threads, and I was able to at least drain the block. Any ideas on what to use for a pry bar? I have an approx. 7/32" hole...
            Jack
            2008 230 TE-ZR6
            • Rick
              • Mar 2004
              • 1250
              • San Diego, Ca
              #21
              I would use an allen wrench or a grade 8 bolt. Both are heat treated for strength.
              Nautiqueless in San Diego
              • Andrew
                • Aug 2005
                • 891
                • Tuscaloosa, AL
                #22
                yep, i'd go with an allen wrench....
                if that doesn't work, then i'd use a steel rod that just fits into the hole. if it bends, heat it cherry hot with a torch, and then drop the bar into a bucket of COLD water (this will harden it) if it breaks, then ur just screwed.... lol, jk....
                give that a shot, if that doesn't work, then i'll need to see a pic of it.... i have an idea, but i'll have to see a pic to describe it, and it'll take quite a bit of work...
                • Miljack
                  • Dec 2004
                  • 1616
                  • Charlotte, NC
                  • '08 230 TE ZR6
                  #23
                  I got the plug out!! :grin:
                  I definitely won the rock ape with a wrench award for this one. I'll post a pic of the damaged plug.
                  Anybody need help winterizing? Yellow_Flash_Colorz:
                  2008 230 TE-ZR6
                  • Miljack
                    • Dec 2004
                    • 1616
                    • Charlotte, NC
                    • '08 230 TE ZR6
                    #24
                    enjoy...
                    2008 230 TE-ZR6
                    • east tx skier
                      • 1561
                      • Tyler, TX
                      #25
                      Man, mine didn't look nearly that bad. 1-1/16" box wrench did the trick for me.
                      • Andrew
                        • Aug 2005
                        • 891
                        • Tuscaloosa, AL
                        #26
                        did u take it off with an ax? lol
                        • bchesley
                          • Feb 2006
                          • 1252
                          • Tyler, Texas
                          #27
                          East_tx_skier,
                          his plug was in the side of the block. A lot smaller and tighter place to work. You should have put a quarter next to it to show how small it really is......
                          Python Powered
                          100 Amp Alternator
                          Dual Batteries
                          • Rick
                            • Mar 2004
                            • 1250
                            • San Diego, Ca
                            #28
                            After chewing it could you spit tacks???
                            • east tx skier
                              • 1561
                              • Tyler, TX
                              #29
                              East_tx_skier,
                              I had a lot more room to work with the block plugs than with the manifold plugs given the exhaust pipe angle off the riser.
                              • WakeSlayer
                                • Sep 2005
                                • 2069
                                • Silver Creek, MN
                                • 1968 Mustang
                                #30
                                I am pretty sure Miljack doesn't have the GT-40, either... he had even less room to work with....
                                the WakeSlayer
                                1968 Correct Craft Mustang
