impeller location
  • TRBenj
    • 1681
    • NWCT
    Originally posted by jeffholloway96
    hey guys well I istalled the new t-stsat and I ran the boat on the flush system for about twenty minutes, during which time the temp stayed at 180. I installed a 143 t-stat. do you guys think this is normal?
    No, definitely not. You should run 150-160 on the hose with the 143 'stat.
    Did you check for air leaks? Common culprits include loose hose clamps on the cooling lines, or a strainer bowl thats either not tightened or missing a gasket.
    1990 Ski Nautique
    NWCT
