heater question and y fitting installation
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    I have a heater in my 98SS that was disconnected by the previous owner due to a leaky core. He then discarded the hardware. I am going to buy new hardware and have already replaced the core. My question is has anyone installed the Y fitting that you can get from SkiDim for increased heat at idle? If so did it help?
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
  • M3Fan
    • 1034
    RE: heater question and y fitting installation
    Is your 98 an EFI model? I don't have the Y fitting and I've never had a problem with heat at any RPM. My heater does great at idle without it.
    2000 Ski Nautique GT-40
    2016 SN 200 H5
    www.Fifteenoff.com
    • Laptom
      • Oct 2003
      • 876
      • Eindhoven, Netherlands
      Our heater came factory, but I've changed it with the Y-fitting in the return line. We also us another heater-exchanger in series of the heater core for LPG conversion and the difference is really noticeble! At idle and at any RPM a perfect heat for the heater and the heat-exchanger for the LPG will not freezes at long idling.
      Well worth the money in my opinion. Even heatercraft recommend it.
      • NCH2oSki
        • 1159
        • Maryville, TN
        • 2005 ski nautique 206 SE
        I installed the Y fitting on my 99' ski. I did it when I installed the heater, so I had nothing to compare it to. Dan at heatercraft told me when I purchased it, that they basically tested it mostly with CC's and would recomend it to anyone installing a heater in a CC. It also makes the heater install very easy in a GT-40.
        Prior Boats:
        1999 Ski Nautique GT-40
        www.skiersofknoxville.org
        • bchesley
          • Feb 2006
          • 1252
          • Tyler, Texas
          Since I dont have any engine connections where did you install it. All I have is hoses hanging so I am starting from scratch and dont have any instructions. I was going to order the Y fitting skidim, but dont know what else to buy in the way of connections. Do you still tap into the side of the block, or keep the tap at the temp sending unit? The instructions on Skidim show to install it before the raw water pump with the barb pointing to the intake. Is that right? I am assuming the increase in flow comes from the raw water pump pulling the water through the heater? Thanks.
          PS. Its GT-40 motor.
          Python Powered
          100 Amp Alternator
          Dual Batteries
          • Laptom
            • Oct 2003
            • 876
            I did it myself on our previous boat with GT40.
            The pick up is at the temperature sensor on top of the block. Just make a T-connection where you also can install the T-sensor onto.
            The return is the Y-adapter, before the raw water pump. This is the easiest install in my opinion, and it gets the hottest water with the best circuilation flow.
            Not a lot of work, if you at it; install some ball valves between the pickup and return line. This way you can compleetly shut of the water flow in the summer, or when the core is leak.
            • bchesley
              • Feb 2006
              • 1252
              • Tyler, Texas
              Great thanks. Cant wait to get a jump in the spring with a working heater...........
              Python Powered
              100 Amp Alternator
              Dual Batteries
              • TRBenj
                • 1681
                • NWCT
                Re: RE: heater question and y fitting installation
                I wonder if thats due to the warmer 'stat on the EFI boats? Our '92 never put out any heat at idle- nothing compared to the '90 with the Y-fitting. Very impressive how that simple part makes such a big difference.
                1990 Ski Nautique
                NWCT
                • bchesley
                  • Feb 2006
                  • 1252
                  • Tyler, Texas
                  RE: Re: RE: heater question and y fitting installation
                  Its does state in the downloadable instructions from Heatercrafts website that you should use a 160 degree stat. My father in laws 99 super air had a heater and I only used it once so I had really no reference to go by. He unfortunately sold it shortly after buying it because my mother in law could not stand how loud the python was. I cried the day that boat left the corral.
                  Python Powered
                  100 Amp Alternator
                  Dual Batteries
                  • TRBenj
                    • 1681
                    • NWCT
                    Re: RE: Re: RE: heater question and y fitting installation
                    That would make sense then- the EFI boats use the 160, while the carb's ones use the 143. Adding to Y to a 143 makes all the difference in the world at idle.
                    1990 Ski Nautique
                    NWCT
                    • wake_fun
                      • 1330
                      • CA
                      • 1995 Super Sport
                      RE: Re: RE: Re: RE: heater question and y fitting installati
                      Look at my install, it might help you.
                      Photo Album
                      Ballast Install 1
                      Ballast Install 2
                      Amp Install
                      PPass Install
                      Alternator Install
