Well, new boat, new platform. So it was time to make it mine. I stripped to bare wood. Scrubbed, brightened, sanded up to 1,000 grit wet (why 1,000 grit? Because I was out of 2,000 grit). Switched over to xxxx steel wool. 3 coats of oil on the bottom. 5 on the top. Light steel wool rub between coats That should hold it until next year.
Let's see yours. C'mon G-Man, I'm looking in your direction.
