Top Speed 206
  • jjackkrash
    • May 2007
    • 498
    • PacNW
    • 2021 Ski
    Top Speed 206
    What are others getting for top speed on an SN 206 with 330 hp Excaliber? I am topping out at 43 mph and wonder if this is typical.
  • ffmedic74
    • 835
    • Lexington, KY
    RE: Top Speed 206
    I have an 05 216 and getting 45 on gps
    • TRDon
      • Oct 2007
      • 722
      • MN
      RE: Top Speed 206
      seems slow to me. My 93 hits 46 on GPS. Mine is a bigger boat about the same weight and I dont know the prop diferences between mine and yours.
      • Edwin
        • 219
        • St. Louis
        Re: Top Speed 206
        What are the rpm's at WOT?
        • TRBenj
          • 1681
          • NWCT
          Re: Top Speed 206
          If thats GPS, that may be about right. My dad's TSC2 196 with the Excalibur tops out at 45-46 (gps), depending on the prop. Thats at ~1200ft above sea level.
          I would expect the 206 to be 1-2mph slower.
          TRDon, I believe the older Sport hull is a bit faster than the new 196/206.
          1990 Ski Nautique
          NWCT
          • jjackkrash
            • May 2007
            • 498
            • PacNW
            • 2021 Ski
            Re: Top Speed 206
            I am ashamed to say I am not sure, and won't know for sure until I de-winterize. I want to say about 4800-4900.
            • MarkP
              • Sep 2003
              • 155
              • Rochester Pennsylvania
              RE: Re: Top Speed 206
              I am getting around 46 depending on the load.
              2004 Ski 206 Limited,Midnight Blue and Black,
              Silver Accents,330 Excalibur,Perfect Pass.
              Nautiques Rock!! My 2004 206
              • MarkP
                • Sep 2003
                • 155
                jjackkrash do you dock dirty bottom will slow it down?
                • jjackkrash
                  • May 2007
                  • 498
                  • PacNW
                  • 2021 Ski
                  Re: RE: Re: Top Speed 206
                  No, bottom is perfect. I trailer.
                  • AirTool
                    • 4049
                    • Katy, Texas
                    I've got an 06 206...just bought it late last summer and had it out only a few times. Most trips were not glassy. In the lake I use that is glassy, it is short so not a lot of time to hang out at top speed. Also, all top end trips had more than one person.
                    Any-who, best I could get was 45 at 4500 to 4600. I've got the 330 with the stock 4-blade prop (422). Previous user left a few dings on the prop but a polished bottom. I sent the prop in for re-work but have not run it since. I'd like to see what max rpm is with the re-worked prop before I order a new prop. I need a spare prop and will likely make the new prop one step towards more rpm and use it as my base prop. I think it will be the three blade 470. I have read the 470 will both increase hole shot and top speed. I will let you know in March.
                    Air Tool
                    • TRBenj
                      • 1681
                      • NWCT
                      Air Tool
                      In my experience on the 196, the 470 will turn about 80-100 more RPM, and pick up ~1/2 MPH on the top end.
                      MarkP, is that 46mph on GPS? Ive found that both speedos (gauge and PP) are off at WOT, despite being accurate at skiing speeds (30-36). PP reads ~49, but GPS speed says 45-46 on the 196 in question. RPM's are in the neighborhood of 4850-5000. I would expect the 206 to be a tick slower.
                      1990 Ski Nautique
                      NWCT
                      • MarkP
                        • Sep 2003
                        • 155
                        It was GPS I was by myself and the water was glass! My speedo is reading higher.
                        • Ginza
                          • May 2014
                          • 2
                          • Lakes entrance
                          • 2007 sn 206
                          I've got an 07 206 with the Excalibur 330 and also acme 422, I would like to know how you got on with the acme 470 3 blade. I am wanting more speed for barefoot.
                          • sodbuster88
                            • Nov 2008
                            • 368
                            • Clayton, NC
                            206 with 330 / 422 not fast enough for footin?
                            Peace..
