Shower Install
  • Flyerace
    • Apr 2004
    • 39
    Shower Install
    Here are some pics of a my shower install on a 206 w/Excalibur.
    I mounted the controls at the top middle of the rear locker. I like them in the middle, because they are easier to reach. I then ran the white hoses to the pump which I mounted next to the rear port engine mount (the electrical wires are bundled there). You will need to drill some holes into the stringer to mount the supplied bracket in this spot.
    The hot (red) hose goes to the engine plug on the port side of the engine and the cold (blue) hose goes to the outlet side of the raw water pump.
    To hook up the dash, look for the same color wire that you used to hookup your pump (this may take some digging under the dash, mine were orange w/ a black stripe and it will be bundled in conduit). Run this wire to your switch or smart pod. If using a simple switch, run a wire from the switch to the fuse panel and install a 10 amp fuse.
  • EchoLodge
    • Jan 2004
    • 616
    • Huntington Beach, CA
    • 99 Super Sport
    Thanks for the pics. I was wondering where to stick the pump in my 90 Sport. Now I know! Cheapest I have see the heater craft shower kit 1s is $183. Did you find it any cheaper and where?
    sigpic
    • Flyerace
      • Apr 2004
      • 39
      I didn't shop for it, so I paid the full price ($299).
      • Frost
        • 161
        Flyerace, that looks almost like a factory installed shower! Great job
        • Moe
          • Jan 2004
          • 56
          • Clemson, SC
          wakeside sells that unit for $165. Just put one in my SAN
          MOE SCHLABACH
          • EchoLodge
            • Jan 2004
            • 616
            • 99 Super Sport
            Thanks for the web site. I will be ordering mine today.
            sigpic
            • EchoLodge
              • Jan 2004
              • 616
              • 99 Super Sport
              I plan on hooking mine up to my anchor light switch on my dash!
              sigpic
