Cool. Thanks
Originally posted by mhunterCan't thank you enough for the information you posted re: using an ipod on a Clarion XMD1. I wired this thing in like it was done at the factory. I actually mounted two RCA's inside my glovebox where my radio is. I was very pleased with the way it came out.
Thanks Again!.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Looks great! How did you handle the switch that needs to be thrown to put the XMD-1 into Acc mode?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
How did I handle the switch?
I have a 03 MC 209 and they give you factory switches on the dash so I used one of the accessory switched. It's just a single position switch mounted on the dash. It even lights up with I turn it on. Again, I can't thank you enough for the info!!!!! P.S. Chris from Mid Ohio says "Hello".
I also have the clarion XMD-1, im looking at doing this next weekend when i pick the boat up from storage.
Questions, the rca lines for aux do make my life easier but what about the toggle between aux and normal? Where do i connect this toggle if im not suppose to use the 13 pin din connector on the deck?
I do have a couple extra keys on my keyless, the 'up' and 'down' keys dont do anything so i was thinking of simply use them to flip a relay everytime its pressed.
Any problems in my thoughts?
Please let me know where the toggle between normal and aux is connected on the deck.
thanks again,
Steven
Originally posted by m3the01Please let me know where the toggle between normal and aux is connected on the deck.
That's on the XMD-3. The XMD-3 has the RCA inputs. The XMD-1 does not. The XMD-1 is the unit that needs this plug.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I can't thank Jeff and A&B enough for this thread. Awesome guys. I was looking how to do this hack and you fellows led us to the promised land. Beers on me.
In my Sea Ray I am doing these mods to install a Sirius sat rad. All of it will be in the glove box and the Sirius recepticle permanently mounted so that I can take the Sirius head unit from car to boombox to boat. While I was at it I decided to add the Clarion APX480M Marine amp. The amp has a remote power up, which I infer is simply a relay telling the amp to power up when the XMD1 head unit powers up. But I can't figure out what lead from either the 16-pin bus or the hacked DIN should be connected to the remote power up on the amp.
Any links to schematics, or ideas?
(Thanks again Jeff and A&B for this awesome thread - have to love boaters who say "How can I do this" rather "It can't be done.")
I just built the cable following the directions posted and reversing the veiw for the pin positions, but when connected to my head unit the right speakers have hardly any volume and I have to turn the volume up higher than normal for the other speakers. What could be my problem. Any help will be greatly appreciated.
I completed a test on the work bench and this setup works great. The XMD went right to ACCS when the switch was thrown. The Sirius sounded great.
Jarabacoa: Standard troubleshooting would be using your FM or CD and if volume is fine there then the problem is in a bad connection. If it is isloated to the right channel it is likely you have shorted the right side RCA inputs somehow. Or, the right side output of your source unit may have a problem, but if vlume is down overall I would think a short in the wiring harness you created.
