There may be an easier fix for this problem. The main problem is that the scoop produces enough pressure to bypass the valves and fill the bags. Simply drilling a hole in the downstream side of the scoops under the boat may eliminate the problem. I am going to try this if I don't have trouble priming my pumps and I do have trouble with the valves being bypassed. If the scoops were completely eliminated I don't even think we would need the valves, but the pumps might be harder to keep primed.
Originally posted by MikeskiThere may be an easier fix for this problem. The main problem is that the scoop produces enough pressure to bypass the valves and fill the bags. Simply drilling a hole in the downstream side of the scoops under the boat may eliminate the problem. I am going to try this if I don't have trouble priming my pumps and I do have trouble with the valves being bypassed. If the scoops were completely eliminated I don't even think we would need the valves, but the pumps might be harder to keep primed.
I just figured the scoop was from the thought that you would fill as you drive, and therefore the assist thus provided would require a smaller fill pump. No?\'01 Sporty Air Nautique
- Jul 2003
- 2908
- San Francisco, CA
- Current 2005 SV 211, due for upgrade! GS22 or GS24 perhaps? Previous
Reversing the scoop will most likely create a vacuum eliminating the ability to prime the pump. We are really just trying to reduce the pressure, I think a 1/2" hole may do the trick. Alternatively the you could use a grinder and elongate the slots through the backside of the "cup".
- Jul 2003
- 2908
- San Francisco, CA
My 2005 SV211 is now showing just under 15 hours, and guess what??? The ballast valves are leaking. The two rear tanks emptied for about 30 seconds after taking 4 slalom passes. I will be talking to my dealer but my gut feeling is that my scoops will be getting the pressure relief holes.
Originally posted by mike-dDr. John,
what happened to your tower situation? any pic's?
Mike
When I was dealing with this, I went out to their lot and checked probably 5 or 6 used Airs/SAN's and I think I only found one that actually lined up correctly (when the two locking bolts were loosened) without some force applied to re-align, so I was hard-pressed to demonstrate my concerns.
I'm sure the dealership doesn't want to see me again, and it would be a real pain to replace it, so I'll wait until the end of the season, as they suggested, to make a decision.
J\'01 Sporty Air Nautique
Mikeski,
That is a really smart idea, let me know if it works.Life is Short, Live it!
http://www.teamcarolina.us/index.htm
I'm very interested also.. as I have a 2005 SV211.. with 0 hrs on it.. so in a few weeks, I 'll probably be back here asking for help...would love some good pics... Not sure how any of the other non-CC owners survive without a site like this one! Keep up the good work all!2005 SV211
2008 220 <--- current as of 1May \'09
A d m i n i s t r a t o r
- Mar 2002
- 16519
- Lake Norman
- Mooresville, NC
I'm waiting to hear back from the manufacturer on the explosion proof version of these valves. The ones I have are not explosion-proof, and I am not comfortable passing along information about non-explosion-proof valves. I should have more information soon.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Correct me if I am wrong but don't CC use a flat skim fitting for the centre ballast pick up so as not muck up the perfect pass. If so does anyone with the centre tank with the flat pick up have the problem of bypassing the valves? I only have rear tanks in my SAN. I like the idea of drilling a hole in the back of the scoops.
