Replacement Faria Gauge Install
  • wake_fun
    • 1330
    • CA
    • 1995 Super Sport
    Here are the instructions for the install.
    Photo Album
    Ballast Install 1
    Ballast Install 2
    Amp Install
    PPass Install
    Alternator Install
  • Rrichr
    • Sep 2014
    • 28
    • Lake placid florida
    • 2001' 196
    Everything was accurate accept my factory installed perfect pass Pro does not have a P/wheel harness under the dash. It goes back by the heater...
    do I just cut the wire and connect the jumper cable in wire by wire?
    • NCH2oSki
      • 1159
      • Maryville, TN
      • 2005 ski nautique 206 SE
      You should have a Main Module for the PP where all of the PP wires terminate, it may behind the kick panel and not under the dash.
      Prior Boats:
      1999 Ski Nautique GT-40
      www.skiersofknoxville.org
