Well the testing phase has pretty much wrapped up…and I’m ecstatic with the progress. I now have a surfable wave on either side of my boat. The switch out takes 3-5 minutes max, allowing for the movement of my NSS wave enhancer, a small amount of water weight, plus 180 lbs of John Deere tractor weights.
Obviously, my original intent was not met…because I can’t evenly weight the boat. With that said…this wave is so much fun! I was 15 ft back dropping in down the wave with enough speed to get past the rear of the boat (on the side). The wave has a ton a push, is pretty clean and just a blast to surf.
The weight remained the same as my previous posts except I was able to add 200 lbs of human weight to the rear and surfsie. The weight does make a big difference but it also works fine with just two of us (one driving and one surfing). The “normal” side or port side wave is still less desirable than the goofy side. The prop rotates right and it makes a difference. This can be compensated for with extra weight. I was able to go ropeless no problem but since I am a goofy rider I never quite felt comfortable on the port side. Here are the pictures:
The standard side is self explanatory but it was very windy thus some of the cleanliness of the wave was washed out.
http://
http://
The goofy wave has my 10 yr old neighbor on a standard surf rope (25ft?), just before he tossed the rope in.
http://
As for pics of the NSS itself, the dimensions are 1 1/8 inch horizontal displacement. I didn’t measure the rest but I think you can tell the rough dimensions based on that one measurement. I might do some very minor mods, but I’m so pleased right now that I probably will just ride most of the summer and leave the tinkering until fall.
http://
http://
http://
http://
http://
http://
http://
http://
http://
