1999 SAN -- replaced engine-hatch actuator with gas shocks and latch
  • scarbs
    • Aug 2009
    • 450
    • Arizona
    • 2017 G23
    I mentioned in the For Sale section that I am going to convert my engine hatch to a 3-hatch system and had already replaced the actuator with gas shocks. There was some interest in some additional information about how I did this initial stage of the conversion so I thought I'd post it here. It was really pretty easy. I purchased some aluminum rectangle tube and some angle pieces from a local metal supply shop. It sells aluminum drops from $1.50-$2.50 per pound so it always really cheap. Anyway, I made two pillars out of the tube, bolted two pieces of angle on the top and bottom and fastened it all with stainless hardware. Then mounted the brackets and shocks. And finally, mounted the latch. Now it lifts easily using the strap attached to the latch and I have a lot more room in the starboard storage hatch. Total cost so far is about $75.
    I plan to finish the hatch after Arizona's long season ends in another couple of months. Sorry for the crappy cell phone pictures.
    2017 G23
    2012 210 TE
    1999 SAN
    1995 Sport
    1991 Sport
  • s_kelley2000
    • 1575
    • Fort Meadow Recevoir
    • Mass
    Good stuff, thanks for posting! Do you remember what stroke length and weight the gas shocks were rated for?
    Shawn
    2012 Blue Metal Flake SAN 230
    • scarbs
      • Aug 2009
      • 450
      • Arizona
      • 2017 G23
      Shocks are 20" long and 60 lbs. each.
      2017 G23
      2012 210 TE
      1999 SAN
      1995 Sport
      1991 Sport
      • stewartsnow
        • Apr 2011
        • 43
        • Vernon BC
        • '00 SAN Python '87 2001
        Any info on where toget the latch and shocks? Great idea, I'd like to make engine dividers this spring and put 750 bags in. The extra room on starboard side would really be nice
        2000 SAN
        Python powered
        • 99SAN
          • Oct 2010
          • 172
          • Roll Tide
          EBay... Look up hatch latch
          • JT96SS
            • Aug 2013
            • 37
            • Farwell Lake Hanover, MI
            • 1996 Nautique Super Sport
            What did you use to screw the brackets into the bottom side of the hatch? The screws on the hinges to my hatch are loose and I cannot tighten them.
            • scarbs
              • Aug 2009
              • 450
              • Arizona
              • 2017 G23
              The hinge "screws" should be bolts with nylon nuts on the other side under the vinyl. You may have to pull the vinyl back to get a wrench on them.
              2017 G23
              2012 210 TE
              1999 SAN
              1995 Sport
              1991 Sport
