03 SAN Limited fall projects (add battery, amp relocation and LEDs)
  • mnwakerider
    • May 2011
    • 271
    • Minneapolis, MN
    Water got super low on our lake so I decided to make my winter projects fall projects. The list:
    * expanding the stock single group 24 batter box on port side to to for two group 24s
    * add perko style switch
    * move amp from PO mounted at drivers feet
    * rewire both amps and mount on port side behind gull wing
    * add LEDs throughout interior
    * tap and mount bolt style 16mm LEDs to tower (using holes from PO light bar)
    What I started with.
    Followed the write up of Core-rider to remove existing interior and them I used a multi tool to cut out the interior. I moved from my original outline to the starboard due to proximity to the stringer. I added a box to give some structure. I coated this prior to installing with resin to waterproof.
    I used some pretty heavy woven roving. 24oz. Harder than I thought to keep the sheets together due to the size of the strands. This stuff sure absorbs the resin.
    I did a couple of layers on the entire box but didn't get any pictures. I was more concerned about the strength at the corners so I added three extra layers of robing like this
    I added resin die to get a stock look.
    I did the final layer with 6oz cloth to clean up the texture. Sticky fingers meant no pictures.
    Jumping ahead after it put the carpet back and cut to the new opening I added both batteries and connected to a mounted common ground and to the selector switch. Looks a little messy but it was the best I could do with the 2 gauge. Click image for larger version
    Notice the grey box? That is where all the relays are for my ballast puppy upgrade. So nice and clean out of the way now. Here is the box open.
    Here is the final with the seat base back in and my trickle charger mounted. Once the project funds are increased I will upgrade to a more legit charger.
    I also moved amps around and sent 2 gauge up to distro blocks. To get the amps mounted to the hull I used hdpe and 3m 5200 and some creative bracing.
    I didn't get any pics without the combing pad of the new amp mount but really happy with how it came out. This is also showing t he new red LED interior lights
    Sent from my iPad using Tapatal
  • mnwakerider
    • May 2011
    • 271
    • Minneapolis, MN
    Here are some interior pics after running waterproof led strip lights through the gunnels.
    Starboard side
    Port behind driver
    Driver side
    Under driver showing gone it mounted
    I found some old single LEDs and decided yo light up the front cupholders. Planning on upgrading to brighter shortly as these are not too bright
    Under port gull wing
    Added a strip inside glove box
    Added a small strip inside the driver side pocket
    Next was the hardest section. The PO had a jeep like light bar (think huge safari style lights on type of tower) and t he were mounted through the cross bars. I wanted to do something with the wholes so I bought 16mm bolt lights from oznium and tapped the wholes to mount down into the interior.
    Tapping
    Mounted
    • mnwakerider
      • May 2011
      • 271
      • Minneapolis, MN
      Found a pic of the amp rack
      Sent from my iPad using Tapatalk HD
      • ski4evr
        • May 2010
        • 613
        • Bowling Green, KY
        • 2005 SV 211
        nice work! led lighting is on my winter list too
        2005 SV-211
        • s_kelley2000
          • 1575
          • Fort Meadow Recevoir
          • Mass
          Nice work!
          Shawn
          2012 Blue Metal Flake SAN 230
          • scarbs
            • Aug 2009
            • 450
            • Arizona
            • 2017 G23
            Looks great.
            2017 G23
            2012 210 TE
            1999 SAN
            1995 Sport
            1991 Sport
